i run the wires directly to the batterys pos. and the negative to the point under the radio (under the center console)
the access gromit is directly in the middle of the passangers footwell behind the glovebox
if you remove the side plastic trims across the passangers front door and fold the carpet back away from behind the glovebox you cant fail to miss it.
My 2nd D8 1.9TD (New Pics)
Re: My 2nd D8 1.9TD (New Pics)
Thanks a lot much appreciated!
Mine's wired into the under bonnet fuse box
1999 D8.5 HDi GLX - Sold
2007 Mondingo Zetec - I seek forgiveness Bring back my 406
Cheers plod, did you use the spare fuse positions in there? If so, did you use one for each seat?plod wrote:Mine's wired into the under bonnet fuse box
If you wired up the heaters as well, did you put them on the same fuses?
As they say, a pic paints a thousand wordsjonsowman wrote:Cheers plod, did you use the spare fuse positions in there? If so, did you use one for each seat?plod wrote:Mine's wired into the under bonnet fuse box
