My SRi Estate
Re: My SRi Estate
thought i would post on here to let everyone know my experience with HIDs on my D9.
before i go on, i don’t want this to find out if my car will now fail its mot or will i get pulled by the police, i merely want to let people know my experience.
the kit i purchased was a H7R whcih is supposed to be for non projector equipped front headlights, and the temperature colour is 10,000K.
i got these in the post this morning and set about fitting them at lunch. took my time and the passenger side went in taking 30 mins and the drivers aside went in taking about 10 mins. i also swapped the side lights for white leds.
i secured the ballasts thus... drivers side is cable tied inside the ecu box and the passenger side is now cable tied to the inside of the battery box.
the kits are simply plug and play really. I have now drilled 25mm holes in the covers for the back of the light units so i could thread the wires through.
conclusion... this colour is quite blue, but in comparison it to my partners HIDs on her ST170 which were factory fitted itrs not too bad. there is a definate beam patern on a wall when parked in front of and there is also a definite pattern on the floor in the dark. the main beams are standard bulbs but are visibly higher than the 'new' pattern. Glare seems to be none which I am very pleased about, but please remember, these HIDs are for reflector lights NOT projectors.
with regards to the mot, i may have a word with the tester prior to testing next year and if he is not liking them, i will disconnect the HIDs and put standrad bulbs in for the test.
from the front with just sidelights on:
close up of the sidelights:
the HIDs on:
close up of the HIDs on:
from inside the car - car parked on drive pointing uphill slightly - see the beam cut off on the hedges:
standing next the the car - beam patern on the floor:
the HIDs on:
Current car - Ph3 1.8 306
Re: My SRi Estate
other things i have done to the car are fitted a front strut brace (no fowling on the bonnet) and shortened the gear lever.
I'm very happy with the car and with me drving it economically, i am averaging 33mpg whcih is goo i think for a big engined petrol car.
Re: My SRi Estate
thought i'd update...
having had some very worrying electrical issues (solved from members on the forum) the car has had a new battery, and i have removed and cleaned up the battery earth point under the battery tray.
i have also removed the strut brace and HIDs (as part of the problem solving above) and these will be sold as i need the cash. when i have some funds, i'll get some whiter bulbs again.
Re: My SRi Estate
how much do you want for the kits mate ? i may be interested
only the kit as 10,000k is not good for road use
i will buy some 4,000k bulbs
Re: My SRi Estate
I replied to your pm. I never had any issues with the 10,000 bulbs. Followed a cop car for a few miles too with them. Maybe I was lucky tho. Anyway it's personal choice. I had 4,300 bulbs in my BMW e30 and they were great.
Re: My SRi Estate
thought i'd post some up to date pictures after ots regular wash
- waue1978
- HDi don't believe it!
Re: My SRi Estate
That little splitter looks good on there Neil - subtle & purposeful. Almost looks factory standard.
Re: My SRi Estate
i never liked that splitter it has a bump in the centre to match the late lagunas it was fitted too.
Re: My SRi Estate
You like it on mine?Gary406 wrote:i never liked that splitter it has a bump in the centre to match the late lagunas it was fitted too.
Re: My SRi Estate
yep i sure do. think i might try that sort of splitter on mine
Re: My SRi Estate
i'm thinking of removing the front fog lights if i cant source some new ones cheaply.
any one have any thoughts on that?
- highlander
- PowerFlow Shill
Re: My SRi Estate
What's wrong with yours - are they all scratched up, cracked, or full of moisture?
You can repair them if they're scratched or full of condensation.
Re: My SRi Estate
they are full of moisture. i have run them on for ages but never makes any diff.
- highlander
- PowerFlow Shill
Re: My SRi Estate
Hmmm.... remove them from the car, and check to see if there's anywhere moisture could be getting in (cracks, splits in the seal between the lens and the plastic body).
Try splitting the lens off them (in a dry environment) and reseal them together (Tiger Seal?)
