Broken o/s foglight (D9)
Hi,
A few weeks ago, I was unfortunate enough to hit a phesant on an A-road (stupid thing was just stood there on the verge and then wandered into the road just as I was going through but anyways!)
Fortunately damage isn't too severe (was doing 70 at the time and it sounded like I'd smashed the bumper off!). There is a small hairline crack on the front of the bumper but the o/s front foglight has smashed (glass is OK but plastic bracket holding the foglight has smashed)
Fortunately, there are a few accident damaged D9s in the local scrappy so sourcing a replacement unit shouldn't be too hard. My problem is fitting it.
The Haynes manual recommends removing the bumper to do it, which according to them, will involve removing the grille and headlights.
If I was to remove the o/s front wheel, would you feel there is sufficient room to get the plastic inner bumper off and get to the light. Has anyone done a similar repair before?
Many Thanks
Many Thanks
Poor pheasant
I'm not sure how you get to the foggies. Have you tried removing the square panel under the bumper, but in front of the wheel. There's about 4 torque screws to remove it, behind there you can see into the wheel arch cavity and the washer bottle/horn is there on the driver's side.
You might be able to reach through this???
Poor phesant !?
(should have took it home and strained it, yum!)
Didn't actually realise there was such a thing underneath the bumper.
Cheers for that, will have to give it a go!
Good thing with going to the scrapyard is at least I can have a 'practice run' first, so if that's how you replace the light, it shouldn't be such a complicated job on my own car.
- diesel406
replacing the fog light
[font=Comic Sans MS] Hi - I need to change my offside fog light too - I have got a new one from eBAY (£24) but I have tried to remove the old one and can't get it out - I then realised there is a screw at the top of the fog light so this looks like I need to remove the bumper to do this job.. I started to do this but got stuck!
1. Can anyone give me some idea how to remove the bumper please? OR
2. Is there a way to get at the top screw on the fog light ? There seems to be som much stuff behind the bumper, I am not sure there is room to wriggle out the fog lamp assembly anyways .. so back to question 1!!
Thanks for your help
Lewis [/font]
Lewis [/font]
Engineer by day - Car mechanic by night - there is a difference!
Now gone to the German Dark Side!!!
At work: http://www.fatigue-expert.com and http://www.xanthusenergy.com
- jameslxdt
im here to save the day
you have to remove the front bumper which involves,
removing the peugeot lion grille, a few clips
removing both the headlights
jack up the car
remove both wheel arch liners
im not sure of where all the bolts are, but there are some on the slam panel, some on the wing and some under the headlights,
be very careful of the radiator condensor and intercooler (where applicable)
also if you have headlamp washers disconnect the was pipes and be careful of the headlamp washers
oh and one more thing the PAS oil cooler runs under the middle at the front of the bumper and is also very delicate so handle that with care
jack up the car
- 1.8 8v
- Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
You dont need to remove the bumper thats b*****ks. It says so in the haynes manual i agree. All you need to do is remove a small cover underneath. This will expose the rear of the fog light. You will need a star headed screw driver bit to remove cover and the two retaining screws holding the fog light in. then there is one in the middle at the top a b*****d to get to but it can be done. Remove cover back from wheel arch and a good torch to see where it is. Refitting is a pain in the arse but i would say use a magnetic screwdriver to get the top screw into position. Replaced mine before xmas around half an hours jobl Also jack car up alittle to give ground clearance for removing cover and foglight screws hope that helps
- diesel406
Rapport25 - nice thought but my Pug has an intercooler and headlight washers so the rear of the bumper is stuffed full of equipment (I saw this when I removed the corner under panel ) no space to swing a mouse, let alone a cat! I do wonder what happens in a front end crash ... yes ... a huge mess! - So it looks like I really do need to remove the bumper .. or pay someone else to do it!
Diesel406
Diesel406
That has shocked me I recently fitted my o/s front fog light and n/s and had no probs unless im being stupid intercooler is on the nearside on the 406 and does not come anywhere near from where you remove the fog light. Word of advice dont just look under the bonnet as i did at first and thought the same Once you remove the corner cover under front bumper and all should become clear
