Scratched Windscreen
gumby6371
Post by gumby6371 »
Using a crappy scraper through the winter has left quite a few scratches in my windscreen, does anyone know good cheap methods/products to remove them?
The low sun in the morning really shows them up and they're quite distracting.
I've found quite a bit of info on detailing sites about glass scratch removal but to be honest by the time I've bought the kit it would be cheaper to pay the excess on a new screen!
Re: Scratched Windscreen
Might be best to 'stage' a new stone-chip bullet hole and have it replaced for new :supafrisk:
If there is a magic fix I'd like to know because I got a little stone stuck on the wiper blade which sent an 'arc' right across the screen :x
TheSongRemainsTheSame
Post by TheSongRemainsTheSame »
It really depends a lot on the depth of the scratch. I've done quite deep scratches on my side window with 1000-grit wet sanding paper and rubbing compound.
The professionals use 1000-3000 grit paper and rubbing compound. You don't need a kit, their stuff is not really special except for the expensive electrical tools that makes the job a lot faster :roll:
Land of the Free?
grasmere59
Post by grasmere59 »
I've used Solvol Autosol,that chrome cleaner in a tube on glass scratches as long as there not to deep,it works wonders on scratched watch faces aswell.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
If there fine scratches they shouid come out,
Toothpaste shifts minor one,s
