Rear Door Check Strap
I know this subject has been raised before but I'm wondering if anyone knows if the door card needs to come off in order to remove the check strap. Thanks in advance.
Re: Rear Door Check Strap
Hi,
A: yes.
IIRC. you will need a 10mm socket /Ratchet,
Atorx T20 bit ithink for the Speaker removal,
And perhaps some New plastic Clips for the Door cards, they often Break, around 17pence each from the Main dealers,
A: yes.
Iwas looking for something with pictures,
Found this, belongs to the coupe club, ihope they dont mind its linked here,
http://www.406coupeclub.org/Files/HowTo ... 0strap.pdf
Thanks lozz.
There's a good Youtube video showing how to remove front door card.
http://www.youtube.com/watch?v=rM5tWpgzgRw
Shouldn't be long before someone posts a rear door one too.
