can someone tell me whats going on?
the front door locks on the out side where you put the key in to some times they work and then they just go round in circles as if the key has not hooked on to any thing,both sides, was looking at a pic on google they looks all electric,
door locks 406 r reg
Re: door locks 406 r reg
squirt a lot of wd40 into the lock. use a straw on a tin of wd and push it in then spray ... the pins inside sometimes stick making it spin round and round
yeah just done that last night seems ok last night see what its like when i see the car again when the wife brings it home,lolGary406 wrote:squirt a lot of wd40 into the lock. use a straw on a tin of wd and push it in then spray ... the pins inside sometimes stick making it spin round and round
just seemed odd it should go back and forth,if its broke its broke.
Spray loads of wd40 in mate,
ive found wd40 seems to dry up and disapears pretty quickly.
so ispray a good quarter of a tin in a iffy lock, good to have a Rag handy tho as ican run down the side of the door,
ive been using Maintance spray from the Quid shops on My citreons stiff locks and it seems to last longer than wd40 that stuff altho its cheap seems to be a thinned out 3in1 oil,
Another point to note,
the D9s im not sure of the D8s. have a Anti tamper feature within the lock,
if someone trys to open the lock with the key or with a differnt key the wrong way, the Barrel will just keep Rotating,
ihad to keep turning the key to the left on my old 406 until the lock wouid work, major pain but atleat it prevents the locks being Razled by theives,
- Bailes1992
Maybe something thicker like canned copper grease? You can get it from halfrauds with a straw like WD40.
I think limitum moly grease would be better again but I don't know if you can get it in a can. Unless you cover the key in it, put it in, have a play, out again, cover it in grease again etc etc.
You can get lithium grease in spray can form - not sure if that's different to lithium "moly" grease?
I'm having the same problem with my locks, will try out the lithium stuff I have.
2002 2.0 HDi 90 Rapier saloon (for sale)
