sill rubber door seals?
johntl
2.2 16v
Post by johntl »
Ive got a 4 door 406 with usual sill rubber problem , my question is where is the cheapest place to bu the rubbers??
Re: sill rubber door seals?
Hi, I got new rubbers recently.
After trawling through eBay I only found one or two and they were £25 + postage, second hand ones are hard to come by.
I eventually went to Peugeot directly, and got them for the same price but without the postage as I picked them up.
Part numbers are;
9023 LJ for the left,
9023 LK for the right.
You will also need some clips, they are only a few pence each ( 6 come with each strip but you need 19 per side in total )
6997 86 is the part number.
Hope this helps....
Kelv.
johntl
2.2 16v
Post by johntl »
Thanks for the info , cheers :)
RichieD
Post by RichieD »
This is great info and should be stickied was looking for the part numbers as my new estates rubbers are knackered.
Richie Dawson
R.D. Automotive
Web:https://www.facebook.com/rdautofy7
lisboa
1.6 8v
Post by lisboa »
hello
I need to replace the sill rubbers on my 2002 2.0 HDI 406 estate but I only see references to the parts 9023 LJ and 9023 LK - are these parts the same for both saloon and estate?
Yes, the parts are the same for both saloon or estate.
I've only owned estate cars anyway - until I bought the Coupé :cheesy:
PeterN
Post by PeterN »
If they are still in one piece you can stick them on with spray on contact adhesive, you need to thoroughly clean the metal surface first, I use meths, not me personally you understand . :?
lisboa
1.6 8v
Post by lisboa »
Thanks for the responses (especially for the meth tip).
They are still in one piece but look the worse for wear (possibly even stretched) so I should probably get a new set. I also have a less than perfect seal at the top of the front passenger door (makes a whistling sound at speed) - initially I thought the door must be misaligned or bent but now i wonder if it's just that the rubber has perished and i need a new set there too.
Thanks again.
beko1987
1.6 8v
Post by beko1987 »
Aha, the thread I need! My drivers one is scrap! Time to see if the part still exists from peugeot in 2018!
