Mud -flaps, cheap ones needed,
Im getting fed up with water spray and mud down side of the car, so ive been lookin at mudflaps, idont like them but they serve a purpose, :roll:
as anyone fitted after market ones?
if so got a linky,?
idont fancy paying peugeot Main-stealer prices for them.
thanks inadvance,
jamjar1383
Re: Mud -flaps, cheap ones needed,
Post by jamjar1383 »
d9 hdi 90 rapier estate
Check the main stealer, I've got a funny feeling that the genuine pug ones are only about £10 per pair. The body-shape moulded ones are a lot more though
I can do that from here, hold on.... nah, they're more than 20 quid a pair. They're also moulded plastic jobbies that are shaped to fit, apart from the "standard" front ones (no rears?) which are like the ones in the link above and represent a massive saving of...... £2.56 :roll:
why not try the big ones ..
ie the ones that go onto subaru rally cars. :cheesy: you wont get spray with the fkers lol
sirwiggum
Post by sirwiggum »
I fitted cheap ones low on the Xantia so it looked a bit like that rally car.
Problem is when it clipped kerbs etc. they were prone to coming loose.
Also, had to make sure it had clearance when it rested on it's belly (Suspension at lowest setting)
Thanks all,
ive got a set from peugeot,
£52 front & rears :shock:
lozz wrote:Thanks all,
Are they body moulded ones?
I've got some old rubber mats you can cut up :cheesy:
ebay have genuine ones £20 fronts. not looked at backs. i was gonna get sum but decided against it
£52 for sum rubber :shock:
ican get ordinary ones cheap but they look tacky,
these ones are shaped to the car an look better, :arrowu:
Well guess what,
they dont Fluckin fit :evil:
are they thick or what at peugeot these look like theyre for a small car,
there going back flung back :(
ishouida just orderd some off flea bay
I've always found mud flaps do nothing, nothing much at all :|
A lot of the muck comes off the upper part of the wheel at speed so misses the flap.
Welly wrote:I've always found mud flaps do nothing, nothing much at all :|
Good point mate,
iwill just get my money back off the thick woods and buy summat else for the car instead 8)
