new on here but not new to working on old car :)
gavintwopies
Post by gavintwopies »
Just bought what seemed a quick fix to my
"I'm sure i need a third car temporarily while i weld up my second one?"
Scenario well the third one a 406 90hdi has had more time money and effort chucked into it than my second choice (GTTDI) that requires welding!!
so im on the lookout for some help with either pp2000 or directions to where i could buy it cheap as i currently have dispalyed
abs fault & braking fault
but to get to this point i have bought and fitted in the last 2weeks.
front drivers bearing.
front drivers track rod.
front drivers ball joint.
front discs and pads.
5 tyres.
2x abs rings
2x front drop links.
repaired the remote key fob.
replaced almost all dash bulbs
So soon as i can start putting posts up sooner i can get the rest of this old girl sorted and put her to daily use to start repaying all that love .. :cheesy:
Re: new on here but not new to working on old car :)
HI mate, welcome.
Your car now has a good front corner - only 3 more corners to go.... :cheesy:
If you add your location to your details on the right then maybe someone with PP2000 can meet with you.
gavintwopies
cheers for the reply I've just updated the location in my profile, car seem to drive OK now but cant really check it as it now needs tax and mot is due in 2 weeks time so just want the last of it road testing prior to dumping it at the mot ctr so i don't get any nasty surprises
