Hi folks
New site member here, but have owned a 406 1800cc Petrol model for about 11 years
I need some advice - for the last 2 days I've noticed a failry loud whistling noise in the cabin when driving to / from work, getting louder as the speed increases. It sounds like it's coming from the passenger side ? The windows are definitely closed all the way, and all doors are firmly closed.
Does anyone have any ideas what the problem may be - door or window seal or something else ?
Steve
Hello - need some advice please!
- lozz
Re: Hello - need some advice please!
Hello.
Sorr'y you've had no replys.
Just an idea /get a Mate to drive car sit in passenger side and then listen in for area the noise is coming from
Hi Steve and welcome aboard.
Can't really add anything to lozz's suggestion, other than to check nothing's caught in either door.
Hi, have you got a sunroof - used to be a weak spot on VAGs....
Maybe, as suggested, get a mate to drive and then had a good look / feel around the doors and try to pull them tight to see if it quietens.
Last resort is to turn the radio up.
Thanks for the replies - turns out it was the window seal on the passenger side front.
The end of the seal was loose, fixing it back in place has solved the problem
