Hello
- 1.6 8v
Hello
Hi Guys,
i am sam and i have just got my wife a 1997 (R) 2.1 diesel saloon 406 it used to be my dads and needs a little bit of tlc to get it back up to scratch (needs all new bushes on the back and the speedo is messing around)
it already has alloys from a v6 coupe and i am part way through fitting the brembos from the same coupe but have accidentally broken the hard pipe on the drivers front already so will need to go to a peugeot dealer and buy a new one. i have also fitted some tinted side windows from another 406.
i will post up some pictures when all is sorted out and running properly
- jonsowman
Re: Hello
Good to see someone else with a 2.1TD! Thought they were getting a bit scarce on here
Pics would be great, how many miles has it done? The speedo thing is a common fault and will be one of two things, either the vehicle speed sensor or dry solder joints on the instrument panel. Both pretty easily fixed at little to no cost
They're great cars, hope you enjoy it.
Re: Hello
Hi & welcome to the site.
- 1.6 8v
Re: Hello
thanks for the welcome.
i do not yet know the mileage as it doesnt come up i think the bulb has gone but i believe its somewhere in the region of 150-175k.
thanks for the info on the speedo will try that when i have sorted out the brakes just fitted the front passenger caliper no damage this time luckily but i broke the locking wheel nut tool trying to undo the first rear bolt andit started to rain hard again so i called it a day.
also forgot to say i am in baldock, hertfordshire.
- jonsowman
Re: Hello
Here's a pic of the back of the instrument cluster so you know what to expect when you remove it.
There are 6 of the large 501 type bulbs for general backlighting, the others are 509T T5 twistlock type. (This is what you'll need for the odo - the one just below the blue connector.)
- midsmike
Re: Hello
i agreeomega wrote:hi
2,1s are the best.
- 1.6 8v
Re: Hello
replacement hard pipe has been ordered £18.07 inc VAT much better than i expected will be picking it up friday after work. just need to make a replacement locking wheel bolt tool now or figure out how else to remove them and get some normal bolts to replace them with
- lozz
Re: Hello
pop in halfords mate,samosizer wrote:replacement hard pipe has been ordered £18.07 inc VAT much better than i expected will be picking it up friday after work. just need to make a replacement locking wheel bolt tool now or figure out how else to remove them and get some normal bolts to replace them with
they sell a tool that gets locking nuts off, around 16 quid iirc,
or ask at local tyre places they might have the tool to get them off,
- 1.6 8v
Re: Hello
picked up the pipe from peugeot today and its just a copper pipe coiled up in a bag with standard end fittings and flares so i will have got to get my brother over to help me with a brake pipe bending tool and maybe put in some extra supports with it being copper instead of steel then we shall see if its the correct length of which i have no doubt it is.
but that will have to wait a little while as i have something very important to sort out that requires eveything else to be put on hold until it is sorted out.
- 1.6 8v
Re: Hello
right i finally found some time to work on the 406 now my driveway is usable again.
brembos and braided lines are finally all fitted and system has been flushed with fresh fluid all round. just needs 2 new tyres and still need to sort out the speedo then i can book it in for an mot.
