I have an 2.0ltr turbo estate and everytime I try to select reverse the engine dies. Starts up and runs in reverse. Its a real pain.
Problem this am. Ran fine for an hour, stopped to get a paper then the car would not start, went for a coffee and a smoke, tried again started and run fine then died at traffic lights and would not restart. I tried to speak to it nicely still no joy. Waited 15mins, ticked off some bus drivers then the thing started.
Any help/suggestions gratefully received
Newbie having problems
- lozz
Re: Newbie having problems
Hi,
Auto or Manual ?
Auto or Manual ?
Hi
Sorry. A bit of a mechanical numpty. Manual.
Ta
Ta
- lozz
Hi My guess is a faulty cranksensor, icouid be wrong tho,
best off getting the car read for fault codes, if you can
Hi
Had diagnostics done but nout found.
Checked with clutch company - they crushed the sensor wires - occasional bridge giving earth fault - replaced section of the loom and new sensor - all ok now.
Many thanks
Many thanks
The clutch is a horrible job on the 406 so I'm not really surprised they caught the wires.
Would help the forum if you add the engine type, i.e. Petrol/HDi etc..
Glad you got it sorted fairly easily.
