Well got my first 406 today 2.0l HDi 90HP LX Estate . I have owned 2 peugeots, 306 2.0L HDI SW (brilliant car wish i still had it) and 3072.0L HDI 90HP which is the wifes run around. I got this 406 after the Megane Cabriolet I owned since September spontaneously combusted , well that was a write off. So we thought we would get something which has some space for all the camping gear with the children. The 406 fits the bill with that huge boot. I know the HDi engines are spot on with two previous ownerships and the engines not needing anything apart from oil changes every 12000miles.
So I found one on Ebay brought for 1185 and picked up today. Well its a bit more dented than i hoped for, but had 70,000 miles and 12 months MOT. Couple of things i noted, I have one remote locking key which doesnt work and the master key with no buttons, at first these just twisted in the lock, but a search on here led me to a WD40 fix, which hopefully has worked.
The petrol flap doesnt spring open ( no spring sited behind the flap should there be one?)
The electrics all work which is great.
The wife informed me of puffs of black smoke on accelerating following me home, I got to 80 MPH on the M-Way no problems , I have read about blocked injectors, but is there a checklist from simplest to hardest to check before i start to work on those.
Oh and Hi... I'll expect i'll be back regularly
Hello and first queries
Re: Hello and first queries
hi welcome
fuel flap
this is well documented but when you open the flap you will see 4 screws round the fuel filler.undo one of them and trap a small spring behind one so the spring rests against the flap[a spring from a clothes peg is ideal]
wouldnt worry about the smoke unless you are leaving a smoke screen.
fuel flap
Hello & welcome.
Probably worth doing the air & fuel filters unless you're certain they've been done recently.
Make sure the cambelt's been done too - due every 72k, but also every 5 years.
Another one... I have no remote unlocking keys , anyone know a cheap place to get some.
I was at the locksmith in Bromsgrove yesterday and they want £140 for a new key cut seem very expensive! So i saw this EBAY Key but i was told by the same key smith you can't reprogramme the keys, is it achievable at home(not the key cuting) but the programming of the remote and getting a key cut with the program on?
Cambelt was on to do list car came with no history (hope that mileage is genuine!) expensive preventative measure , more expensive cure!
Well the car has gone for the cam belt change today... The mechanic had to cut the under tray bolts off as they were seized, which makes me suspect the oil hasn't been changed in a while.Doggy wrote:Hello & welcome.![]()
I was informed the cam belt was on its last legs and loose, the water pump had two fins missing.
I have the oil filter so that's next on the list as is the air and fuel filters, then perhaps its happy motoring for a while?
You don't have to take the under-tray off to do the oil change, you can let the oil run off the back of the tray (it's not that far). The under-tray fixings are always in a mess, they're rubbish and best assisted with big washers/tie-wraps etc. I fashioned an incredible assortment of fixings and had no trouble........then the mechanic cut them all off and made his own.........the tray was gone within a few weeks, I mean properly gone - I still miss it to this day
I wouldn't worry about black smoke unless it's really chugging out. There's no particle filter so smoke will be more visible, things like leaking turbo hoses, EGR valves, carbon build-up can all lead to more smoke but see if it settles down after a small service.
I would believe the oil had been changed if the rim of the filter wasnt rusty and there was evidence of oil on the under tray.
Oh on the undertray theme mine is a 2000 and i have only ever seen these http://www.ebay.co.uk/itm/Citroen-Peuge ... 970wt_1163 but mine had a bolt and captive nut, is that correct?
try driving vehicle hard through all gears after adding a cleaning additive. This is a comon fix pre-mot as carbon builds up in the exhaust due to echonomical driving. The cars behind you may have an interesting journey MartinR
- rwb
+1 on a set of filters
I recommend Wynns diesel injector cleaner. You can get it quite cheaply on eBay. One bottle into a quarter of a tank then take it for a long Italian tune-up
