Hello
I am new Here
and just purchased a 1997 406 glx Diesel
the time clock is not illuminating
it is a separate clock in a triangular shaped setting just to the left of the main speedometer and rev counter
could any one help me by telling me
how to remove the clock and if there is a bulb behind it i can replace
it keeps good time but has no back light to help it be seen
thank you all so much
clock
- mjb
Re: clock
Not needed to do it myself, but you just need to lever it out and change the bulb - commonly available from halfords, any motor factor, maplins, etc
- HimBigChief
Re: clock
As above. It just pops out. I used a thin flat bladed screwdriver down the sides to get mine out. Can't remember off hand whether it's a normal dashbulb holder or one of the shorter ones, but you'll find out once the clock's removed.
