Stoney here new owner of 406 110 hdi estate
- Newbie
just bought a 406 110 hdi estate, needs a few bits doing but seems solid enough
Re: Stoney here new owner of 406 110 hdi estate
Hi & welcome to the forum.
Hi, welcome. A good choice of car and engine. Hopefully the forum folk can point you in the right direction for your needs but there is plenty of information in the knowledge base section, and also by searching for problems, somewhere between the banter and idle chit-chat ......
- Newbie
had a quick look around and it seems I have a few common problems, spent this afternoon poking and prodding at the car, so far I have found and fixed some of the following
Low on power = fixed was a slack throttle cable
Air bag light on = fixed was a connection under the seat
Drivers door lock = fixed wd40 and a wiggle
grinding knocking noise = clumps of dirt in wheels and springs!
multi display dim and only showing date and time?
wipers park too high?
Stereo works but beeps loudly?
Strange noise from behind clocks when you first open the door?
Climate control resets every time and sometimes takes a while to turn off?
The wipers bit is unusual, do they overlap the screen when driving down the road
Can simply slacken the wiper arm nut and adjust the wiper arm down by moving it round the spline a bit.....
Oh dear mate!,stoney wrote:had a quick look around and it seems I have a few common problems, spent this afternoon poking and prodding at the car, so far I have found and fixed some of the following
1st off welcome on in & the 110 hdi is a good car but has it's fault's.
Cheeck out my post's in the i.c.e section re-stereo beeping
2006 BMW e61 535d m-sport
run's for cover
