HDi alternator belt routing
Knowledge Base Articles
Locked
stevemc
Post by stevemc »
just to make matters worse, my alt belt snapped ,i can not work out witch way it goes on the pulleys ,its a 99 hdi with air con ,a picture or diagram would help alot .thanks steve
legoless
Re: alernator belt
Post by legoless »
Hi
I dont have a picture but this may help .. from wikipedia search:
Starting from the crankshaft pulley and going clockwise looking at the pulleys, the belt goes thus: Ribbed side against the crankshaft pulley, then flat side against the tensioner pulley, ribbed side around the power steering pulley. Then the flat side against the idler pulley running ribbed side around the alternator pulley then down to the air con pulley running ribbed side around that and back to the crankshaft pulley.
Re: alernator belt
Here ya go.
Reason: Pics moved to imgur
Re: alernator belt
Nice one Teamy - should go in the KB, (the number of times I've scratched my head over it). :oops:
TopDonkey
Re: alernator belt
Post by TopDonkey »
I keep a complete spare HDI engine in my garage just to refer to when i need to do anything on any of my HDI cars !!, its a bit of overkill, but i rarely get stuck because of it
Locked
