Coolant temperature too high warning message on a D9 406
- jameslxdt
so the fan isnt cutting in then i take it?
- jameslxdt
a/c system pressure is too high then, the fan will only hit full speed if coolant temperature is critically high or of the a/c pressure is dangerously high
oops.. if thats only one fan then it should be a two stepper motor .. check this.. start the engine... switch off a/c .. wait until temp hikes upto 90 ~ 95 like.. see if the fan engages.. if that engages fine at low speed then fan and relay mechanism works properly.. and then the culprit most probably the a/c pressure sensor.. sometimes back same happened to me. even temp goes to 100 fans doesn't engage + even if i switch on a/c fans doesn't engage. after 100+ degrees fans come at high speed. found the bottom relay which triggers 2 fans in serial mode has gone..
- jameslxdt
this is practically impossible as the HDi runs so cold, the fan never seems to cut in to cool the engineHarshan wrote:oops.. if thats only one fan then it should be a two stepper motor .. check this.. start the engine... switch off a/c .. wait until temp hikes upto 90 ~ 95 like.. see if the fan engages.. if that engages fine at low speed then fan and relay mechanism works properly.. and then the culprit most probably the a/c pressure sensor.. sometimes back same happened to me. even temp goes to 100 fans doesn't engage + even if i switch on a/c fans doesn't engage. after 100+ degrees fans come at high speed. found the bottom relay which triggers 2 fans in serial mode has gone..
hmm.. dunno much on hdi's but my 1.8 Gasoline acts like I explained.. even if the temp is less than 70 fans engage and start working in low speed as soon as i switch on the a/c .. probably ECU does something with external temperature as well. I'm in a tropical country so the temp outside is always above 27 so that might be the reason and one another thing I noted that is in day time as soon as temp goes up to 90 with A/C fans start running at high speed.. and in the night even temp goes to 95 fans doesn't step into high speed mode.. probably something to do with external temperaturethis is practically impossible as the HDi runs so cold, the fan never seems to cut in to cool the engine
Foghorn Leghorn wrote:cheers Mike
Not sure why I didnt see the img tags first time round, doh!!!
Fog
Hi fog.. many thanks for the valuable advises here.. could you please help me locating the fan resistors.. I've played out with fan relays, fan wire harness up to under the battery cover .. fan main fuses.. but never came across with fan resistors. may be i've seen them but couldn't recognize.
- jameslxdt
there is no fan resistor as such, you have the fan switch in the thermostat housing, the three relays and the bitron sensor or cooling fan ecu hidden behind the left front wheel arch liner
- Foghorn Leghorn
- 2.0 Turbo
That happens on mine quite a bit now, but the cooland temp gauge is eratic, often does not work then shoots up and warning light comes on. Is they a temp sensor somewhere that could be the problem, if so where?
Vehicles I own:-
Vehicles I own:-
