Washer motor gone?
nimike
Washer motor gone?
Post by nimike »
02 2l petrol D9 - sometime over the cold period, the washers have quit. Havent actually looked under the bonnet yet, or checked the fuses. pipes may have come off / fuse blew / washer motor quit.
Is it a big job? How much for the motor?
cheers
Mike
hammerman
Re: Washer motor gone?
Post by hammerman »
Could just be that they were fozen.My froze,& when trying to use them,i could`nt here the motor/pump working,on the front or rear washer.Yet now they are working,i can here the pump.
I think you have to remover the front drivers side wheel arch liner to expose the washer bottle & pump. :)
2003 Hdi Est SE
It's under your r/h front wheel arch liner, at the front. Nice place to get cold and freeze up.
Deffo check the fuse first though, if you've tried to run it when it's full of slush it could easily have blown the fuse. Happened on my mate's astra last week.
nimike
Post by nimike »
DaiRees wrote:Deffo check the fuse first though, if you've tried to run it when it's full of slush it could easily have blown the fuse. Happened on my mate's astra last week.
forgot to post back. yes indeed it was the fuse. cheap fix. cheers for the replies.
Glad to be of service :D
