abs light on
abs light on
Recently my abs light comes on when I go above/around 60-70mph . I have cleaned the front sensors but no change , any ideas before I have to spend the christmas money at the main stealers?
Re: abs light on
have you checked the top up level for the brakes? it could be air in the system too. are your brakes spongey / solid? any work been done on the brakes lately?
Re: abs light on
psm406hdi wrote:Recently my abs light comes on when I go above/around 60-70mph . I have cleaned the front sensors but no change , any ideas before I have to spend the christmas money at the main stealers?
Check the ABS rings on the front driveshafts (CV joints) for cracks or breakage.
Re: abs light on
the brake fluid low warning does come on when the hand brake is on even though the fluid level is ok , I might have to check the rings , are they expensive ? and are they easy to fit?
Re: abs light on
Mine used to say ABS fault on the display.
A new handbrake switch cured it!
D9 2.0 HDI, 406, GLX, 110
Re: abs light on
Surely the handbrake switch cured the brake fluid warning light and not the ABS?
ABS has nothing to do with the handbrake switch.
