Hi folks! just found out that my 406 has a gap of about 1/4 inch between the plastic intercoooler pipe running under the engine and the turbo outlet pipe. I didn't have time to investigate further, are these a push together fit or is a bit missing? Any light on the subject would prevent me from getting the car up on the ramps and going under it in the p!ssing rain!
regards, craig.
2.1 td turbo outlet to intercooler pipe question
- 1.6 8v
Re: 2.1 td turbo outlet to intercooler pipe question
does the car work alright? you have turbo boost? can you post a picture?
Hmmmm, straight 6 goodness!
