D8 mileometer and clock illumination?
Posted: Wed Aug 19, 2009 11:30 am
by carlo14
Morning all, anyone help with this one?
The illumination for my 1998 Exec dashboard clock, and mileometer/odometer went recently at the same time, although both displays are working if you peer at them very closely. I tried replacing the clock with another, same problem; and also replacing the clock bulb but it makes no difference. The clock works but it doesn't illuminate. Before it conked out completely it did work a couple of times if you banged the dash above it (the clock).
I did actually have a hand control fitted just before they both went out, but I can't see what could have happened here or if it's related.
Ta!
Re: D8 mileometer and clock illumination?
Posted: Wed Aug 19, 2009 12:44 pm
by omega
are all the clock lights dim or just the two?
Posted: Wed Aug 19, 2009 12:56 pm
by carlo14
Just the digital clock on top of the dash, and the dual mileometer/trip meter under the speedo. The actual dimmable dashboard display (rev counter/speedo etc) lights are fine.
Posted: Wed Aug 19, 2009 4:51 pm
by john170277
i know this might be a daft question have you tried the fuse
Posted: Wed Aug 19, 2009 5:05 pm
carlo14 wrote: ...it did work a couple of times if you banged the dash above it
Ahh, percussive maintenance, I love it. That'll be a dodgy connection then.
Posted: Wed Aug 19, 2009 10:30 pm
by carlo14
Not the fuse, checked that.
Posted: Thu Aug 20, 2009 10:48 am
by jbh325i
what fuse does the mileometer/trip meter as mines isint lighting up either
Posted: Thu Aug 20, 2009 10:50 pm
by coolverbatim
Hi all
Can't help on this but have a problem on my 1997 406 estate petrol 2L. The speedo and rev counter are both on the blink except when they decide to work. I also have problems with only some of the lights working the rev counter and speedo but these never work. If I whack the top of the dashboard, i can sometimes get the speedo to work!!!
Any ideas?
Just joined so newbie so please go easy!!!
Alan
Posted: Fri Sep 11, 2009 7:57 pm
by Chaz
coolverbatim wrote:Hi all
Any ideas?
Alan
I think there is a common issue with bad solder / dry joints on the rear of the clock panel. Ill be removing mine soon too - similar issues and speedo works whenever it wants.
Posted: Sat Sep 12, 2009 12:11 pm
by swiss
Certainly the operation of dash gauges can be affected by dodgy French soldering. Whacking the dash is a temporary fix, more long term you need to pull the bastard out, split the cluster right down to expose the PCB and re-solder every single joint without soldering in any shorts :)
I've not heard of this fault affecting the dash/clock illumination before. When I've had lights out, it's always been the bulb - thus far. My clock light is out at the moment, so if/when I get off my arse and fix it I'll let you know what'd happened :)
