noises
noises
hi all bit of a strange one i need help with please i was parked up today and got in my car when i heard a bang almost like a handbrake cable snapping but my handbrake is ok i checked it when the recovery guy turned up he said i have a snapped rear spring upon further investigation i cannot find a break has anyone had anything like this happen to them any ideas please
- Site Admin & Mad Biker!
Re: noises
We have had quite a few snapped springs, check around the bottom of the spring & you'll probably see the break or a doubled up coil.
I did one a couple of weekends back, careful with those spring compressors!
Re: noises
thanks will look round there tomorrow and will let you know
Re: noises
Is it a 02 plate?
Hmmmm, straight 6 goodness!
Re: noises
no its a 99 if that helps
Re: noises
I don't think you need one for a rear. Strange, more often than not it's a front spring that goes...teamster1975 wrote:We have had quite a few snapped springs, check around the bottom of the spring & you'll probably see the break or a doubled up coil.
- puggy
- Resident Pervert
Re: noises
Did the recovery guy tell you which spring it was ?? did he see where it had snapped ??
if you have checked thoroughly and cannot see anything you may have suffered something
that occasionally happens with my car, when i park and pull the handbrake on get out and
later return and get in the car i hear a bang very rarely this happens and i found it to be
the handbrake , when i pulled it on it must not have quite engaged and when i get back in the
extra movement or weight makes it drop a notch with a loud bang
Re: noises
Hold on there Pugster, sounds like a knackdid ratshit to me
I'd say watch out for it doing a Passat (i.e. rolling away merrily down the hill with no-one inside it) but I'd think you leave it in gear anyway.
Re: noises
puggy wrote:Did the recovery guy tell you which spring it was ?? did he see where it had snapped ??
upon further investigation both back wheels off both springs antiroll bar link rods etc checked i even checked the drums and i believe you may be right about the handbrake slipping thanks for all the help guys once again fantastic advice and suggestions
- Captain Jack
Re: noises
Hmmm... The bang could be the pads/shoes sticking to the disk/drum (via rusting to it). I had that before with my 1st '6 if it had been parked for a few weeks etc...
- puggy
- Resident Pervert
Re: noises
But of course my goodly friend steve , i thought all 406 owners parked their car in gearsteve_earwig wrote:Hold on there Pugster, sounds like a knackdid ratshit to meI'd say watch out for it doing a Passat (i.e. rolling away merrily down the hill with no-one inside it) but I'd think you leave it in gear anyway.
Re: noises
Exactamundo. Mine works tho, now 8 clicks and counting
