Page 1 of 2
Air Con Pipes
Posted: Mon May 25, 2009 3:09 pm
by Matt
are the high pressure air con pipes very expensive for D9's? 2.0 Hdi if that makes any difference
had my air con looked at today and the high pressure line that crosses over the low pressure line at the front has developed a leak, i saw it for myself
are these pipes expensive?
Matt.
Re: Air Con Pipes
Posted: Mon May 25, 2009 4:03 pm
by puggy
Any chance of a picture ? if its one of the 2 pipes that go under the battery tray and
at the back of the brake servo then into the bulkhead these come as a pair £68 i had
mine renewed at main stealers , the pipes replaced system re-gassed £300
could be cheaper if its one of the other pipes .
Re: Air Con Pipes
Posted: Mon May 25, 2009 5:26 pm
by Matt
Hey Puggy
heres a pic of the pipe in question
you can see the yellow dye leaking from it, the guys says its likely to be 3hrs plus the cost of the part, regas is included
Re: Air Con Pipes
Posted: Mon May 25, 2009 6:16 pm
by kebab22
mine went in the same place. replaced pipe myself took about a day to do. pain as you have to remove the servo and cross over bar
Re: Air Con Pipes
Posted: Mon May 25, 2009 7:07 pm
by Matt
i might just pay someone else to do it if its a fiddly job i hate them kind of jobs, last thing i did on mine was a broken suspension spring, which was pretty annoying because i needed to use two sets of spring compressors becuase the spring was huge and 1 set wasnt long enough...took ages
how much did you pay for the pipe?
Re: Air Con Pipes
Posted: Mon May 25, 2009 7:51 pm
by kebab22
i think the pipe was about £50-£60 mate
Re: Air Con Pipes
Posted: Mon May 25, 2009 9:44 pm
by puggy
Exactly where mine went Matt ,
like i said they come as a pair £66.78 from main dealer but you could probably get them
fitted cheaper at independant garage .
Re: Air Con Pipes
Posted: Tue May 26, 2009 11:03 am
Re: Air Con Pipes
Posted: Tue May 26, 2009 12:29 pm
by Matt
seems to be a very common problem on these,
Just been quoted £190 for the whole job, part, fitting and regassing of the system.
does anyone have a part number for that pipe so i can call a few other garages and get some different quotes
i'm not exactly jumping for joy at the prospect of paying £200 to fix my aircon
Re: Air Con Pipes
Posted: Tue May 26, 2009 12:44 pm
For £190.00 that doesn't sound too bad to me.
Pipes: £70.00
2 hrs Labour: £80.00
Refrigerant, dye and oil: £40.00
Total = £190.00
Makes sense to me
Re: Air Con Pipes
Posted: Tue May 26, 2009 12:59 pm
by Matt
yeah, you're right, i think its more that its having to pay it, it caught me by surprise, ah well, it'll be worth it when its done, especially if the summer is going to be as hot as people are saying
Re: Air Con Pipes
Posted: Tue May 26, 2009 1:33 pm
Matt wrote: especially if the summer is going to be as hot as people are saying
Pffft!....they always say that
I think it's to stop people booking Holiday's abroad
Unless you already know this the 406's air con is WELL worth having - it's brilliant
Re: Air Con Pipes
Posted: Tue May 26, 2009 1:58 pm
by teamster1975
Welton wrote:Unless you already know this the 406's air con is WELL worth having - it's brilliant
How does the Volvo's compare Welly?
Re: Air Con Pipes
Posted: Tue May 26, 2009 3:36 pm
teamster1975 wrote:How does the Volvo's compare Welly?
About the same I suppose although the Volvo suffers with glare off the dash
Re: Air Con Pipes
Posted: Tue May 26, 2009 4:28 pm
by puggy
6460 R1 is the part number , and i agree with welly £190 is a very good price
