306 brake question
Posted: Mon May 18, 2009 8:18 pm
I've noticed with the 306 that if you jump in and drive off immediately, for the first couple of minutes the brake pedal goes rock solid and braking efficiency is severely diminished
After a couple of minutes though, the pedal returns to "normal"
I was wondering if an ingress of water (hygroscopic brake fluid) would cause the problem or whether it's something more serious
Also I've mentioned the clutch pedal is almost on the floor all of the time, there's only about 2 inches maximum movement, it's really stiff and I have to remember to dip the clutch all the way, otherwise it's impossible to engage gears, unlike the 406 which performs flying changes up in record time and down the box with no effort at all.
The dealer said it would need a new clutch in about 4 months but I'm not sure that that is the problem, someone else said that the cable had probably stretched and to change that first, however there is no thrust bearing noise, which was my first thought so if anyone else can pinpoint the problem it would help immensely.
