Prolonging clutch life
Posted: Mon May 11, 2009 10:32 pm
by mjb
So of late I've been driving everywhere as grandad-like as I can but today I was in 5th gear, 1500rpm, gave it slightly too much throttle trying to keep up with a 1.1 fiesta and it slipped
So it's got me thinking since I can still get about sharpish in low gears when the ol' red mist descends
... Would it not help prolong the life of the clutch if I went everywhere around 5000rpm (accelerating slowly) instead of trying to keep revs as low as possible?
Re: Prolonging clutch life
Posted: Mon May 11, 2009 10:56 pm
by Doggy
Not sure - if you're right Honda Accord clutches will last forever.
(Recently heard one owner saying he was going to change his for a car with something called torque).
Posted: Tue May 12, 2009 6:55 am
I would probably amble about town in 3rd mostly, say around 3000 rpm....try it and see if it helps?
Posted: Tue May 12, 2009 8:27 am
by mjb
Welton wrote:I would probably amble about town in 3rd mostly, say around 3000 rpm....try it and see if it helps?
That's about 50mph, not quite ambling
Drove to work this morning only using 1st and 2nd. Pedal feels so horribly vague and slow, but I didn't really feel it slipping while in gear. Think I'll be heading down to Wolverhampton in 3rd ;)
Posted: Tue May 12, 2009 8:30 am
To be fair a slipping clutch can be nursed along or ages as long as you don't try 1-in-4 hill starts etc
Posted: Tue May 12, 2009 8:48 am
by jasper5
Best way is to accelerate gently in all gears, as soon as you feel the slip, back off the revs until it doesn't slip, then gentle acceleration again.
As Welton says, try to keep away from hill starts and avoid the hills as much as possible.
Posted: Tue May 12, 2009 9:11 am
by mjb
jasper5 wrote:As Welton says, try to keep away from hill starts and avoid the hills as much as possible.
Yeah, that's not much of an option round here
Posted: Tue May 12, 2009 10:10 am
I wonder if clutch replacements are directly proportional to the landscape of the area
*moves to Lincolnshire*
Posted: Tue May 12, 2009 10:33 am
by eoin27
Speaking of prolonging clutch life. Could anyone tell me the difference between
this (a HDi 90 clutch) and
this (a HDi 110 clutch). If the 110 clutch is built stronger to take the extra 20bhp of power, i'll get one of those.
Posted: Tue May 12, 2009 11:57 am
They look the same but caution is the key as I believe they should not be the same at all
The 90 has a solid fly but the 110 has a dmf -that shouldn't really affect the clutch itself but I've a feeling the 110's is bigger diameter.
What you need is some kind chap wth Service Box to have a looky.
BTW the LUK ones are
supposed to be pretty good.
Posted: Tue May 12, 2009 12:21 pm
by eoin27
ya, the DMF factor entered my head alright. Notice in the auction, they mention that you will recieve a Luk
OR a Valeo. Which is it??
Posted: Tue May 12, 2009 10:45 pm
by Doggy
Right then.....
90
00002022J1 Clutch kit £213.26 DW10TD & Gearbox BE4R
0000205145 EXCHClutch kit £113.52 DW10TD & Gearbox BE4R
110
00002052F0 Clutch kit £222.25 DW10ATED & BVM ML5T
0000205142 EXCHClutch kit £165.09 DW10ATED & BVM ML5T
All of above 225mm according to HBOL
136
000205260 Clutch kit £236.25 DW12TED4 & BVM ML5T
000205241 EXCHClutch kit £179.80 DW12TED4 & BVM ML5T
242mm
Posted: Wed May 13, 2009 6:07 am
So they are different then, it seems.
Posted: Wed May 13, 2009 11:22 am
by bangernom1cs
HI,
Not that I've had the problem ..yet. Apparently D9 clutches arent as good as D8's.
Five people up and going around North Wales all the time would you think cause problems but I'm hoping that mine will last.
On the D8 1.9 I changed the clutch as a precaution when the gearbox came out for a bit of fettling at 200k.
The replacement Valeo clutch is still working well in the car 240k on and thats had solid urban taxi work inc the North Wales hill runs. Compare this to my old Montego diesel which went through a total of four in the same mileage!
I believe that the thing (told by old mechanic)that wears clutches out are sharp fast starts and rough gearchanging and clutch riding. Smoothness it would seem is the key.
T
