front brake calipers
I am gong to be replacing my front brakes but need to a torx for this can anyone tell me what size of torx bit i need, i think it's either 50 or 55, can someone please advise so i know what to buy. It's the rapier saloon if this makes any difference
Re: front brake calipers
If you are taking off the caliper bracket to replace the discs, you will need a 55 torx bit, if you are just replacing the pads, you only need a 13mm spanner to undo the bottom bolt holding the caliper down, pull the caliper away and swivel it up, then pull it out of its slot.
- HimBigChief
If replacing the discs, you'll also require the right size torx bit for the screws which hold the disc to the hub face. Possiby T25?
T30 for the discs
