Injector Cleaning
Posted: Sat Feb 21, 2009 9:26 am
by mjb
I've been wanting to know this for years (I really wanted it doing on my tubby!) but can one of our recent additions to the forum possibly tell us how to go about finding a localish company with injector cleaning facilities?
Re: Injector Cleaning
Posted: Sat Feb 21, 2009 9:52 am
by mark21TD
Just look in the yellow pages or Google for a diesel specalist.
Posted: Sat Feb 21, 2009 10:04 am
by puggy
G.W.Dale newcastle street burslem are the local diesel specialists
mj dont know if they do petrol injectors but could be worth giving
them ring cos if they dont they will no doubt know someone that does :)
Posted: Sat Feb 21, 2009 11:02 am
by jasper5
Believe it or not, injector cleaning on a petrol engined car is very simple.
Provided you can get at the injectors easy enough, they are usually only held in by a clip and a wiring connector, there will be some sort of rail that they fasten onto.
Once you have them out, (they just pull out of the head from their rubber seal) you can only clean up the nozzle area, this is good enough usually.
In the past, I have done this and pumped injection cleaner into a new filter or in the fuel pipe that goes to the injectors using a hand primer like the diesels have.
I do quite a few Peugeot 206's with injector faults, I pull them out, wash them off, then refit them, mixing up where they fit, ie, 1to4,4to1, 2to3,3to2.Works a treat every time.
