Hi Guys
Can any of you tell me if my D9 X-reg 110 clutch, is hydraulic or a cable?
Just that ive noticed on the odd ocassion,the clutch doesnt always come back to the top when my foot is taken off it, this causes it to sound like im reving the engine and not going anywhere.( if u know wot i mean)
Any help much appreciated.
Hydraulic or cable?
Hydraulic or cable?
D9 2.0 HDI, 406, GLX, 110
Re: Hydraulic or cable?
Hydraulic. I've tried searching because I'm sure there's an assist spring that screws up but I can't find owt
- 2.2 16v
It's hydraulic with a DMF( Dual Mass Flywheel). If the pedal is not coming back up check nothing is fouling the slave cyl,(top front of gearbox). Also check it's not something fouling the pedal. Is it making any noises?
- 2.2 16v
As far as I know that was on some D8's( number 5 in this picture) http://www.aussiefrogs.com/forum/attach ... 1229924130 I know I havn't got one on my car or I'd have seen it when I fixed the clutch/cruise switch.steve_earwig wrote:Hydraulic. I've tried searching because I'm sure there's an assist spring that screws up but I can't find owt
D9G 2 21M 20A 07 2148 54 01 ASSIST SPRING- ML5C MANUAL GEARBOX AND RIGHT HAND DRIVE
Then again, I guess it's either broken or it aint.
I cant hear any strange noises, only noticed this cos my clutch bites near the top, was only replaced last year by previous owner.
Thanks for all your help.
- mjb
- Site Admin
On the D8, if you detach the master cylinder from the pedal, the spring becomes very noticeable and either pins the pedal to its usual resting position, or when you push it past half way, to the floor.
Is the D9 setup the same, because this new car's got a very vague, spongy feeling to the pedal...
The lack of servicebox is killing me
