top engine mount
ncd72
top engine mount
Post by ncd72 »
hi all need help again - does anyone have a rough idea how much the top engine mount on the drivers side is from the dealers - the one with the spring about 6" long on it?
its for a s 98 lxs diesel by the way
thanks
neil
Re: top engine mount
Neil,
If you do a search for ServiceBox & how to use it - this will give you all the info you need - it looks as if the mounting is an assembly & you may be able to change just the necessary bits, but there are several versions, so have a look yourself
