Fram Fuel Filter
- averagejo
Fram Fuel Filter
guys,
got a service kit off ebay and came with a Fram fuel filter (G5857) is this a direct replacement for one that should already be on the engine or should i just be splicing the fuel line and jub clipping it in? if so any recommendations where abouts?
thanks
dan
thanks
dan
406 GLX D9 2001 2.0l 16v EW10J4
- mjb
- Site Admin
Re: Fram Fuel Filter
If it's a cylinder about 2" diameter, 4" length with hose connections at either end and an arrow embossed on it, it's probably a straight replacement. You'll probably find your existing filter under the car between the rear drivers side wheelarch and the back door. It's a messy job and I strongly recommend the use of latex gloves and hose clamps
- averagejo
that sounds like the one, will have to go have a check for those arrows though.
Dan
Dan
- mjb
- Site Admin
The arrow indicates fuel flow direction. It wants to be fitted with that pointing forwards
- averagejo
no arrows but there was an out marked which is obvious enough
however...... been under the car this morning and still cant find the stock one to replace
is it under the wheel arch lining? according to the haynes the mount should actually be next to the fuel tank but i just cant see it
dan
dan
- Site Admin & Mad Biker!
If it's anything like the tubby it'll be clipped (or cable tied
) under the car just in front of the rear offside wheel arch.
- averagejo
if its in plain sight it def isnt there..... only explanation is that its hiding under a panel or something or just not there - is that even possible?teamster1975 wrote:If it's anything like the tubby it'll be clipped (or cable tied) under the car just in front of the rear offside wheel arch.
assuming that its not there or even that its hidden somewhere, where abouts in the engine bay would be a line i could tap and run into it?
some random shots of the fuel tank and pic from the haynes i was going from.....
dan
- mjb
- Site Admin
It should be just off-picture to the top-left of the wide angle photo. I changed my last one without even jacking the car up...
- averagejo
thats the 'IMG_2947.JPG' right?mjb wrote:It should be just off-picture to the top-left of the wide angle photo. I changed my last one without even jacking the car up...
will try and take another look.... 'hopefully' before the weekend, but pretty damn sure its not there as having the replacement i already knew what shape i was looking for - besides the fuel line running in and out should be a dead give away :-/
thanks
dan
- mjb
- Site Admin
I had an idea...
According to servicebox, later EW10J4 D9s (since 08576, whenever that is - you'll have to check your VIN) only have a fuel filter for dusty conditions spec cars
- averagejo
VIN is VF38BRFNAxxxxxxxx
according to service box under engine....
Particle filter WITHOUT PARTICLE FILTER
im guessing particle filter is fuel filter?
dan
dan
No, that's the particulate filter in the eggzorst on some HDis.
- averagejo
bugger, thought i was onto something there steve
AS RPO No 08838 89 2 0669
dan
is that number part of the VIN or this...mjb wrote:According to servicebox, later EW10J4 D9s (since 08576, whenever that is - you'll have to check your VIN) only have a fuel filter for dusty conditions spec cars
dan
edit: agrees with mjb -
I've used your vin in Service Box and it looks to me like your car doesn't have an in-line fuel filter, presumably if it has anything it's part of the in tank fuel pump.
- averagejo
thanks, would it be advisable to couple this fram one i have into the engine bay?steve_earwig wrote:edit: agrees with mjb -
at this moment im hanging my hopes on anything that could clear my antipollution fault
thanks
dan
