Hi all
i am new to the 406 Owners club.
i rencenlty bought a 1999 406 and have discovered the power steering has a leak. I have looked and the resevoir seems to be fine as does the pipe that goes to the pump. i can see fluid on the the on the wheel arch near the resevoir but i cant see any holes. does anyone know if this is a common issue.
any feedback would be greatly appreciated
Power steering leak
Re: Power steering leak
Hi there, welcome aboard. I don't know what you've got but on mine the clip on the bottom pipe had gone loose and ps fluid was pouring out and running along the inner wing and dripping off the chassis rail below the ecu. I cut it off carefully and replaced it with a jubilee clip.
Hi.
Had this on mine. The pipe that runs from the resevior to the pump is mostly metal with a bit of flexible as well. it was the lower joint between the flexible and the metal. Tried jubilee clips which reduced the leak, but I ended replacing the pipe. About £35is squid. Not too difficult once you take out the headlight.
Regards,
Richard.
Regards,
Richard.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
- Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
Welcom aboard. Steve is right the same happened to mine ages agosteve_earwig wrote:Hi there, welcome aboard. I don't know what you've got but on mine the clip on the bottom pipe had gone loose and ps fluid was pouring out and running along the inner wing and dripping off the chassis rail below the ecu. I cut it off carefully and replaced it with a jubilee clip.
- Site Admin & Mad Biker!
Yep, same thing is happening to mine, I spotted it yesterday. It's where the rubber hose goes into the top of the pump; trip to halfords (againrapport25 wrote:Welcom aboard. Steve is right the same happened to mine ages agosteve_earwig wrote:Hi there, welcome aboard. I don't know what you've got but on mine the clip on the bottom pipe had gone loose and ps fluid was pouring out and running along the inner wing and dripping off the chassis rail below the ecu. I cut it off carefully and replaced it with a jubilee clip.
Welcome Kyle!
- 1.6 8v
Hi all
thats great. i will check this out tommorow but it sounds like mine is doing the same thing - leaking on the right hand side wing and then dripping to the ground. the leak is not too bad but i need to fix it before it damages the pump.
thanks so much for all the help.
