hi guys think i found my problem.i turned off the blower and the car now runs and the alternater now charges the battery.is bthere an erth on the blower or unit or is it faulty ignition switch any info would be great
cheers dave
think sorted the non starting unplugged the blower it starts
Re: think sorted the non starting unplugged the blower it starts
You could have posted this in your original topic mate.
I posted on that one before I saw this one. Now I feel aggrieved that I wasted my time posting on your first question when you already knew the answer
If you unplugged your blower and now your car starts and charges properly I would suspect that it is your culprit.
The blower switch is still in and plugged in I assume ?
As you modifiy car switches with leds, presumably you've got a multimeter. Use that to check for a short from the blower switch.
If that is ok then put a new(er) blower in.
If you start loosing charge again, its something else
Simon.
2000 2.0l hdi 90.
2000 2.0l hdi 90.
hi where is the blower switch located?
cheers dave
cheers dave
