re 406 1.9 diesel
re 406 1.9 diesel
hi first of all you got a great site here and only just found it well done.i am having problems with the wifes peugot 406 diesel it is a nightmare to get going in the morning wont fire sometimes for 10 mins i have changed the diesel filter cuz it sound slike diesel strarvation and had glow plugs checked but now im stumped any ideas.
Re: re 406 1.9 diesel
Glowplugs?
sorry should have said we have had them tested
- ianst28
- 2.2 16v
- Location: sunny wirral (who am i kidding it's always bl&^%y raining)
just out of interest have you tried pumping the hand primer under the bonnet if so does that make any difference ???
If at first you don't succeed, skydiving is not for you !!!!!
- Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
On my 306 i had this problem and it was worn out glow plugs. Untill i could afford to replace them i use to turn ignition wait for glow plug light to go out do this around 3 to 4 times then the car should fire straight up
I doubt that would be the problem as the old xud diesel engines once primed via pumping the hand primer after changing the filter would never cause any problems after the car had been run.ianst28 wrote:just out of interest have you tried pumping the hand primer under the bonnet if so does that make any difference ???
- ianst28
- 2.2 16v
that wasn't quite what i was getting at i don't know if it happens much on the 406 but a mate who had a citroen zx 19td had a starting prob every morning it just wouldn't start he could sit there for ages winding it over then eventually it would kick into life but run like a bag 'o' shi!e for 5-10 minsrapport25 wrote:.I doubt that would be the problem as the old xud diesel engines once primed via pumping the hand primer after changing the filter would never cause any problems after the car had been run.ianst28 wrote:just out of interest have you tried pumping the hand primer under the bonnet if so does that make any difference ???
anyway cutting the long and painfull story down after changing everything he could and taking it to several garages a guy in the pub told him to replace the diesel spill off pipes on the injectors as they where prob perished and letting air in he did this and cured the problem total cost was about £5 plus a couple of beers
just sounded like a similar problem
Interesting never heard of that before. Very good point. You learn something new everyday
Could be air in the fuel lines, which would be a similar symptom to worn spill lines/worn primer pump
