406 front mount help
i'm doing a front mount intercooler on my exec turbo and wondered, i'll obv need 2 remove the old cooler, but the 2 fans in front, will my car over heat if i take em out?? thanks
- jameslxdt
Re: 406 front mount help
take them out and see what happens
- mjb
- Site Admin
Yes.BRADYBOY2K8 wrote:i'm doing a front mount intercooler on my exec turbo and wondered, i'll obv need 2 remove the old cooler, but the 2 fans in front, will my car over heat if i take em out?? thanks
You will be able to travel at speed fine, but as soon as you drop under 30mph with a warm engine you'll overheat in a couple of minutes, if that.
would co2 spray help 2 prevent this? because really i dont see the point in having a front mount 2 cover it up the gay fans, lol
what if i kept the fans but behind the front mount with air directed towards them using ducting stuff??
- Blue406
- 406 Gimp
Bit of a silly question really.BRADYBOY2K8 wrote:i'm doing a front mount intercooler on my exec turbo and wondered, i'll obv need 2 remove the old cooler, but the 2 fans in front, will my car over heat if i take em out?? thanks
The fans are there for a reason, much like the wheels and tyres at each corner of your car!
- Blue406
- 406 Gimp
If you do it right, might work. Remember to reverse the motors, or you'll just blow the air AWAY from the engine!BRADYBOY2K8 wrote:would co2 spray help 2 prevent this? because really i dont see the point in having a front mount 2 cover it up the gay fans, lol
I think you're shaping up for an overheat though.
cheers, once i take everything off, i'm hoping i can move the fans inplace of the old cooler ( still drawing air towards the engine )
it looks as if there is enough room to mount a new cooler and position the fans further back
dont know if that makes sence to you :S lol
Why would you want to remove the cooling system from the engine? Surley this would result in over heating? These fans tend to be put there for a reason.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
i know there 4 a reason but i need a way round it, how do other cars with front mounts run with out over heating??
i'm hoping i can mount the front mount in front of the fans and direct air to them via induction hoses, not sure tho
- puggy
- Resident Pervert
cant you mount it lower down behind the grill in the front
bumper and re-plumb the pipe work ??
- Blue406
- 406 Gimp
They design the engine bay and cooling system accomodation to account for it.BRADYBOY2K8 wrote:i know there 4 a reason but i need a way round it, how do other cars with front mounts run with out over heating??
