ok i'm new to owning a 406 and new to diesel and i'm confused there is loads of info about but i figured i would ask
do i need a kit to run veggie oil or do i just mix it with my diesel in the tank or do i avoid it like the plague i really have no idea so any help is much appreciated
thanks all
veggie oil
- ianst28
- 2.2 16v
- Location: sunny wirral (who am i kidding it's always bl&^%y raining)
veggie oil
If at first you don't succeed, skydiving is not for you !!!!!
- 2.2 16v
Re: veggie oil
Depends on your fuel pump type, see this - viewtopic.php?f=1&t=4171
- 1.6 8v
Re: veggie oil
I have only ever tried it on the older type diesel engines 1.9 and 2.1 12v but you can run it pure without any modifications dont know about the HDI engines as they have a few more electrics attached to them, I did find that mixing it with diesel does make the car run better though and I only use clean oil as I can't be bothered straining lumps of fish batter out of it. also If you use the used type you can't use it in the winter monthats as it set in the fuel injectors I had this problem a while back with a 405 and ended up warmin the fuel rail with a blow lamp to get it started. So my sugestion is run it 50 - 50 for the best results.
- Site Admin & Mad Biker!
Re: veggie oil
Don't put veggie oil in an HDi! It'll wreck the engine!
Re: veggie oil
I have been using veggi oil in my 2.1 TD estate with the Lucas pump. It has been running well. I have been adding about £10 of diesel per full tank. The only thing im noticing is that at times it idles a little rough, but I believe that the fuel filter needs changing and that will solve that little problem.
- ianst28
- 2.2 16v
Re: veggie oil
well i finally tried it after talking to a few people i figured it was worth a go so i put 30l of fresh veggie oil in and washed it down with 20l of diesel first trip to work was nerve racking let me tell you but so far after 200 miles all seems good no probs at all only thing i really need to do is change the fuel filter and i'll prob get that done this pm while "she" is out shopping
Re: veggie oil
um....????I have been using veggi oil in my 2.1 TD estate with the Lucas pump
i thought you couldnt do it with a lucas pump as i previosly asked here......
as i have a 2.1TD and wished to do this, but after what was said, i didnt really wanna risk my injectors, and anything else that gose with it lol
how long have you been using it for?
If Itz Got TiTz or Tyres, Itz a Pain in The Arse
Re: veggie oil
[2p] A friend of mine has been experimenting with his 1996 VW poo-lo 1.9d and steadily increased the concentration of veggie oil (which is now expensive) until his fuel pump crapped out and scrapped 3 injectors
£600.00 car, 'cheap' fuel, £500.00 in repairs - go figure
[/2p]
[/2p]
Re: veggie oil
I was under the impression (possibly incorrect) the problem with the lucas pump is the seal and that the veg oil "eats" them. The pump/fuel lines then start to leak. Whether this is true and how longs it takes i don't know....
1997 Honda Prelude 2.2 VTi
