hdi engine shuddering when accelerating
my hdi 90 engine shudders when moving from stationary, or even if i let the clutch out slightly (biting point)
its gets worse every day, but once its going along its fine. could this be a worn torque mount?
thanks in advance.
thanks in advance.
2.0 hdi mk2.....
Re: hdi engine shuddering when accelerating
The 90 is not renowned for clutch problems but you can never rule this out. The rear lower engine mount (with the drive shaft passing through it) can also cause this shuddering - can you detect vibration as the car rides over a crest in the road?
- mjb
- Site Admin
is this when accelerating, or just when coming off the clutch?
coming off the clutch, if you give it lots of revs its ok.
2.0 hdi mk2.....
I'm with Welton, probably an engine mount but it could also be your friction disk's soaked in oil.
thanks chaps, there is a bit of an oil leak so thats worth concidering. as soon as i get my jack back of loan ill crawl underneath and check the torque mount.
2.0 hdi mk2.....
- mjb
- Site Admin
It's the mount, early stages of failure. The top mount seems most the most common to wear.cajunmart wrote:coming off the clutch, if you give it lots of revs its ok.
- Site Admin & Mad Biker!
I hate to say this but it could possibly be the thrust bearing in the clutch too
i did think of the thrust bearing, thatll be a pain to change! i hope it the mount though.
2.0 hdi mk2.....
Thrust bearings usually make a god awful racket when they're on their way.
i bet its the thrust bearing, i now have to drop the clutch at 4000 rpm to avoid the noise.
2.0 hdi mk2.....
Hopefully James will drop by and read this thread, he's the resident genius!cajunmart wrote:i bet its the thrust bearing, i now have to drop the clutch at 4000 rpm to avoid the noise.
Trouble is he defected; sold his 406 and bought a Passat
Usually but not exclusively
- jameslxdt
knackerd clutch pressure plate, a worn thrust bearing (or release bearing) will give you a high pitched squeal or rattle at idle untill you depress the pedal
