Work christmas do last night, so my car's been sitting at work for 2 days. Get in it this evening (below zero temperature), fire it up, and it starts shaking! It felt like one cylinder wasn't firing but revs were steady at 900rpm as normal and it didn't sound any different! When it warmed up a little (still hadn't moved by this point) the shaking stopped.
Any ideas?
Shaking
- Site Admin & Mad Biker!
Re: Shaking
Put a scarf around it!
Sounds like a misfire, condensation on the leads?
Re: Shaking
The poor thing was scared, you cannot just go abandoning the poor dear on these cold winter nightsmjb wrote:my car's been sitting at work for 2 days ... and it starts shaking!
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
Re: Shaking
Mine does it too but only when it's really cold.
My Xantia which had the same engine also did it so I'm going with "characteristic" rather than fault. Which means I don't have to fix it
New glow plugs might sort it, if one isn't working it might take that cylinder a second to get going.
Cheers
Steve
Cheers
Steve
She cannae take it captain!
Proud owner of the Funbus 98 2.1td estate being reborn £70 at a time.
Still need new back-plates.
- mjb
- Site Admin
Re: Shaking
It wasn't mis-firing, I'm pretty sure of that because there's a drastic increase in noise if you pull a lead off. Wonder if one of the injectors was playing up though...
