Hi All,
My D8 1.8 have never gone through any suspension repair until I've put my hands onto it.. I bought it last November and last month I decided to do a complete job on underneath, coz the ride was uncomfy and bumpy and some noises. So went ahead and replaced all 4 shock absorbers with gas shocks and all links front are rear , ball joints, steering rack ends and rack end arms all that. It has been a month and now it start being rough on bumpy roads here in Sri Lanka. no noises at all but the car jerks a lot when running through pot holes and wrinkled tar roads. any where specifically should I look into ? and I feel something wrong with the anti-roll bars.. coz car jerks a lot.. but can't say for sure.. any suggestions where to look into? any help is really appreciated
/harshan
Help - Suspension problem
- 2.2 16v
2007, 407SW HDi 2.0l
1980, Volkswagen GolfD 1.6l
Re: Help - Suspension problem
Errr, if it took a month to show up, I'd reckon either you picked a duff part up or something's come undone. Bounce the corners (do the shocks all feel the same?) and have a grovel about with your spanners. If the geometry's changed it might make for a very twitchy ride...
- 2.2 16v
steve_earwig wrote:Errr, if it took a month to show up, I'd reckon either you picked a duff part up or something's come undone. Bounce the corners (do the shocks all feel the same?) and have a grovel about with your spanners. If the geometry's changed it might make for a very twitchy ride...
thanks steve .. yup all feels same.. but i was thinking of getting a shock test done.. and as you said it can be some bad fitting as well... got to check all that... and i can guarantee the parts I used
- 1.6 8v
My 406 hdi s is a bit hard as well. Do these have the same struts as other 406 models?
