Front suspension
- 1.6 8v
Front suspension
I have recently aquired a 51 reg estate hdi 90. I need to change both front suspension bottom ball joints, the ones that screw into the bottom of the strut. I understand i need a special tool. Has any one ever done this job and if so is it reasonably straightforward? And is it easy to get hold of the tool?
Eat, Sleep. Play Ice Hockey
Re: Front suspension
done quite a few on 405's & 406's now-i stick the hub carrier in a vice,put some gentle heat on the carrier then get it out with stillsons-put the new one back in with a cycle spanner-dont forget to chisel the 'staked' bit first & then stake it once its in.
Proper tool was a total waste of money i found.
- 1.6 8v
