What make of brake pads do you use?
Re: What make of brake pads do you use?
Custard proof or else my friendsupa-de-dooper-frisk wrote: I changed my pads myself a couple of months ago, and then - I did them myself and it cost £20 - and then - after all they're a piece of cake to do
- jameslxdt
i use apec pads as i can get them super cheap from maccess (trade only) i used to use mintex but they dont stock them anymore and nowhere does them cheap
- jameslxdt
unless the bolts or calipers are seized
- jameslxdt
mines a '97 and as im so fussy it gets messed with almost every other day, ive given up on it now though
- 2.2 16v
last set i used were powertrain but not great wouldnt have used them but my dad already had a set in his garage from when he owned it, problem being that the bloody tension clip has fallen off and now when theres no pressure on the brakes the pads rattle like buggery in the caliper rather annoyingly,will be mintex in future!!!!!!
- mjb
- Site Admin
Whilst were on about pads. I have noticed my front discs are pretty worn at the edges.
What make of disc/pad can be recommended and how mucho?
I don't like it when brakes go really noisy when they get hot though.
The rear discs on mine run really clean so I thought I would just get new pads and get the caliper cleaned and lubricated/freed up.
- mjb
- Site Admin
I took a car full (5 adults plus luggage) through the peak district the other day. Unfortunately my Extreme Grandad Driving seems to vanish as soon as I hit the first sign of a nice country lane so I was driving hard (nowhere near as hard as I'd be driving alone but hey I still got air!) for an extended period so my brakes were taking a fair old battering and I'm happy to report they worked flawlessly with no sign of fade even after the smell of the things got quite substantial
I'm definitely sticking with Lucas after that.
- 2.2 16v
Discs
Just fitted brembo discs to my 90HDi, the car brakes soooooo much better now. From past experience, you pays your money and takes your choice, cheap discs wear and warp far quicker. I would also agree, new disc and pads every second pad change or 60-70k, but the Brembo have wear indicators drilled into the disc to remind you when to change - clever buggers
- jameslxdt
get ATE discs or ATE power discs, they are amazing and either lucas pads (depends on what calipers you have) or mintex pads or ATE padsWelton wrote:Whilst were on about pads. I have noticed my front discs are pretty worn at the edges.
when did you last have the brake fluid changed Welly?
