Hi all,
Apologies for the trivial question but I'd like to replace the spark plugs on a 1997 2.0 Turbo (XU10J2TE) and the layout is slightly different to what I've found online for (presumably later) petrol engines. Instead of a plastic engine cover and a single ignition coil pack for all four plugs, I seem to have individual ignition coils. I assume it's as straightforward as unplugging each coil and replacing the spark plugs (I have all the bits to do this), but I wanted to check before wrestling with the delicate looking plugs.
Spark plug change 2.0 turbo (XU10J2TE)
