Page 2 of 2
Re: Flywheel locking tool for 406 automatic
Posted: Fri Nov 11, 2022 6:53 pm
by WillNZ
Oh, and a compression test will not pick up minor leaks in cylinders, you need to do a cylinder leak down test to pick those up.
Posted: Wed Nov 23, 2022 12:36 pm
by okehdokeh
Sorry for the late reply but after my last post things got worse with the 406 and I landed up pulling the cylinder head off of it. It develop a loud chirping noise when the oil temperature hit about 90 degrees, at this point it also started to suck in some oil from the oil return galley next to #4 cylinder and burn it.
I had the head checked/skimmed and valves and seats re-cut (Engine services in Leicester for £80), the car is now back together and running well again.
All in my 406 has recently had a re-con turbo (shaft bearing spun and blocked oil way on old one), new water pump, timing belt and pulleys, a re-con high pressure fuel pump plus the head work already mentioned. Luckily I was able to do all the spanner work myself so saved a lot of cash there, maybe if I had to pay somebody for the labour costs the old girl would have had to go
If anyone ever does this job and shears half of the torx head off of a head bolt as I did
I have made a two piece guide tool for drilling and milling the rest of the bolt head off in-situ and you are welcome to use it
Thanks for all the advice and help again folks, Paul.
