A couple of days ago my clutch pedal went straight to the floor. Upon investigation, the rubber section of pipe near the slave cylinder has been chaffing (over quite some time I suspect) and eventually worn through.
Is this a relatively easy run of pipe to remove? I can possibly get it repaired if it is.
Are replacements available?
As per my sig, the car is a 2003 2.2 HDi
Slave Cylinder pipework
- 1.6 8v
2003 2.2 HDi Executive Estate
Re: Slave Cylinder pipework
Looks like a job for a hose supplier such as Hose Doctor or Pirtek ...
If you are happy to go down the second hand route, there is a breaker called BBautos, he can be found on eBay.
- 1.6 8v
Thanks,
Is it easy to remove? Without having to take half the car apart?
