Hi all right I have a big issue and not sure where to start I have a 406 2.0 hdi 110 estate 02, whilst parking up pulled the handbrake the a few seconds after heard a loud pop from around the tunnel and the next day i had more turbo lag than ever and whiteish smoke under acceleration , which gets worse the longer i drive any ideas ?
iv been underneath and found no hoses damaged also noticed a slightly crimped oil hose at the rear of the sump. I've checked the pressure on my intercooler but once the revs go up theres a boost of pressure and it falls off really quick with the revs still high is that normal ? Cheers all
Turbo lagging
Turbo lagging
2002 406 estate 2.0 hdi 110 rapier
Based in Buxton Derbeyshire.
IF ITS NOT BROKE DONT FIX IT!!!
Re: Turbo lagging
Check all the vacuum hoses for a start but I suspect the white smoke maybe oil which could mean the turbo seals are failing.
Re: Turbo lagging
Cheers I have been under the car and no sign of leaks I'm wondering if the slightly crimped pipe is an oil pipe to my turbo if so reducing lubrication to my turbo any idea if it's a high pressure line.
Re: Turbo lagging
Oil is blue smoke,
White smoke is unburnt diesel or water in the diesel.
2002 110 HDi estate, Rapier in monaco blue! ( found quite a bit more power ) SOLD I've sorted the airbag light
2006 206 1.4 16v sport in Aegean blue ( wife's shopping trolley )
2006 BMW e61 535d m-sport run's for cover
