I changed my air filter today and the old filter had a grey spongy section (1 cm thick) attached to the bottom of the yellow fins . this seemed to operate as an extra layer or filter? However , the new filter I ordered had no such grey filter. Is the grey bit an optional extra or is it vital?
I couldn't understand why the replacement did not have this .
Air filter question - 406 hdi 90 2003 plate
Re: Air filter question - 406 hdi 90 2003 plate
HI & welcome aboard Phillipe.
I think both versions of air filter element are common, I would not worry about it as either style will prevent unwanted debris being digested by the engine.
My previous air filter had the grey spongy section, the current does not. There is no difference.
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 690.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
It does sound like the grey spongy bit performs no actual function then ? It's a bit of a funny one because it makes you wonder why they bother with it then if it makes no difference?
Maybe there is a difference (in life span) when driving in dusty conditions.
Current "fleet":
Previously owned:
Previously owned:
