Problem with RPM on Peugeot 407
Hey, I have a problem with the Peugeot 407, in my drive slowly reverses, the reversing speed returns fast, but as soon as the wheels rotate and if it is not in the speed if I squeeze a little gas, the rush keeps up and slowly descends ... did not lose its strength.
Re: Problem with RPM on Peugeot 407
That makes no sense whatsoever, Google translate strikes again. Niš ne kužim.
I hope it’s now better..
https://youtu.be/Ljr3uItawrM
I'm not totally sure what I'm seeing there but I think the car is cutting the power when you try to reverse?
- rwb
I don't get it.
I see the ESP error. Do you have an ABS sensor out?
It looks to me a bit like the revs rise and fall when the clutch pedal is being depressed and released?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Yea, the ABS/ESP senasors is dead, but when i press gas pedal the RPM goes up, just like the gas pedal is stuck(5 sec) but it isn’t, and there is no error on dignostic except ABS/ESP
