Hello
Posted: Sun Dec 03, 2017 10:18 pm
Hi fellow 406 V6 lovers. Could some one tell me were the engine number can be found on the engine. It's had a recon put in so water pump needed changing and slight oil leak so took my baby to bits. Were is the best place to get a clutch kit from. I would need engine number to find out what clutch would fit yes or no?. Also while it's out the inlet manifold, the cast is there something that can be done to shine it up. Cheers people
