2.2 hdi coolant boiling over
Posted: Fri Oct 02, 2015 9:27 am
by billybob69
my car was loosing coolant so cleaned out new thermostat and coolant but same thing again.
i felt return flow pipe to header and not hot so could that be a problem, will check once cooled. i think previous owner had issues as there was gunk round tank from past.
could it be head-gasket i did rev it but seemed to be ok but not sure if a subtle leak somewhere.
Re: 2.2 hdi coolant boiling over
Posted: Fri Oct 02, 2015 10:22 am
by lozz
Get a local garage to do a pressure test..they normally don't charge much..a fiver or so.
Or you can make your own tester..out of an old header cap and tyre valve..
Posted: Fri Oct 02, 2015 11:56 am
by billybob69
took cap off and looks like smoke coming out of header and on revs water surges out, so i think it is knackered.
Posted: Fri Oct 02, 2015 12:36 pm
by PeterN
Head gasket failure usually causes water loss when you push it, poodling about the pressure doesn't get high enough but run it at full throttle under load and it will often empty the cooling system.
Posted: Fri Oct 02, 2015 12:39 pm
by billybob69
that sounds like what has happened. i noticed a lot of crap around tank so i think it is a long term thing. i will sell for scrap.
Posted: Fri Oct 02, 2015 12:45 pm
by PeterN
Around the header tank is a good place to look when you are buying, any white deposits, streaks or signs of it being cleaned arouse suspicion.
