Throttle cable clip
billybob69
Throttle cable clip
Post by billybob69 »
My throttle cable in engine bay is slack and causing a few issues. Cant see the clip anyone know the pn number or where I can buy one to tighten it up.
2002 406 2.2 hdi glx estate
staffs
Re: Throttle cable clip
I have a couple of spares I keep in case mine falls off, but I have instead tied a bit of string around the 2 ends to make a loop so if it falls off then it is suspended by the string... :idea:
The part number is 1639 31- Retaining Clip.
billybob69
Cheers did you buy it from the dealer.
staffs
dirtydirtydiesel
Post by dirtydirtydiesel »
billybob69 wrote:Cheers did you buy it from the dealer.
:lol: Nah gingers a serial 406 breaker :supafrisk:
binnzy
Post by binnzy »
I just got some stiff wire and bent it with pliers to sit in the grooves
If it doesn't fit you need a bigger hammer
