Engine starts, and just cuts out.
- 1.6 8v
Have a 90bhp hdi 406. and it starts. runs for a minute and just cuts out .... the autodiagnostics light is also on.
Re: Engine starts, and just cuts out.
Maybe lift pump failure? If it has one - Is the hp pump Siemens or Bosch? (Does it have the the squeezy bulb thing towards the back of the engine? Looks kind of like a grenade...)
- jonsowman
Whereabouts are you based? Putting the car on Planet would probably help
Diagnostics of some sort anyway, without that you'd be guessing...
From Darren's previous posts, seems he's in Ireland, so 'over' to Frank?
He was looking at Rapiers. so I'm guessing a Seimens equiped 90.
Check filter housing etc for fuel leaks?
In-tank strainer, maybe?
I seem to remember something about the crank sensor too (anyone?) but if it's a Siemens then diagnostics is the only way to go.
Darren123 wrote:Have a 90bhp hdi 406. and it starts. runs for a minute and just cuts out .... the autodiagnostics light is also on.
These are the same symptoms as the HPi petrol that I just fixed recently, fuel pressure regulator was the problem, but I agree with others....diagnostics first!
